-   -   1958 Cast iron powerglide linkage adjustment? (http://www.hotrodders.com/forum/1958-cast-iron-powerglide-linkage-adjustment-228622.html)
lilrobo 01-20-2013 01:33 PM
i have a 2 speed P/G tranny ,, with 235 motor ,, the only adjustment for shifts are at the tranny ,i just dont know how to do it ,, i need to make it shift just a tad sooner ,i can make it shift by feathering the gas pedal ,, any ideas ??
thanks
anglia427 01-24-2013 08:50 PM
early p/g
adjust the linkage from the carb to the trans throttle pressure give it a little less
lilrobo 01-25-2013 04:05 AM
The only way i can adjust it it at the tranny, on the 235 there is no adjustment on the rods, , i would have to remove the rod at the tranny and do ilt there,, i can do though,, i just dont know weather to go clockwize or counter clock wize, ,i am thinking clockwize, because when i am giving it the gas, i can ease up on the gas and make it change,,,, giving it the gas is counter clockwize, ??
Thanks
