1958 Cast iron powerglide linkage adjustment? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2013, 01:33 PM
i have a 2 speed P/G tranny ,, with 235 motor ,, the only adjustment for shifts are at the tranny ,i just dont know how to do it ,, i need to make it shift just a tad sooner ,i can make it shift by feathering the gas pedal ,, any ideas ??
thanks
Old 01-24-2013, 08:50 PM
early p/g
adjust the linkage from the carb to the trans throttle pressure give it a little less
Old 01-25-2013, 04:05 AM
The only way i can adjust it it at the tranny, on the 235 there is no adjustment on the rods, , i would have to remove the rod at the tranny and do ilt there,, i can do though,, i just dont know weather to go clockwize or counter clock wize, ,i am thinking clockwize, because when i am giving it the gas, i can ease up on the gas and make it change,,,, giving it the gas is counter clockwize, ??
Thanks
cast iron powerglide rhoffler Transmission - Rearend 2 12-21-2010 09:27 PM
1958 Chevy Impala 348 Cast Iron Powerglide slingslingbinks Transmission - Rearend 2 09-12-2008 09:06 AM
cast iron powerglide slingslingbinks Transmission - Rearend 2 05-24-2005 05:50 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Cast iron powerglide slingslingbinks Transmission - Rearend 13 09-30-2004 10:18 PM
