We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 06-05-2002, 12:07 PM
58Delray 58Delray is offline
New Member
Post 1958 Chevy drum-disc conversion
Greetings,
I am looking for any information on what make/model of GM vehicle could be used for converting front brakes to disc. Any info would be much appreciated.
Also was considering how much work it would be to convert to power steering.
Thanks
Old 06-06-2002, 09:07 AM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
Post
I would call Master Power Brakes and ask them what they sell to do it. This may provide a clue as to what donor cars may do the trick. It is going to be tough in any event because the donor cars are going to be scarce.
I solved my problem on a 67 Camaro suspension by going to the library and finding a parts interchange book for that year. The stock disc brakes spindle, rotor and calipers each had a number which I search with to find other cars and other years which were the same. I finally found that 67-69 camaro and medium sized cars all had the same discs available, usually as an option. This gave me many cars as possible donors and I searched until I found one. Master Power Brakes would have done if for $1000, it cost me time in the library and $50.
Also get on car nut websites and ask if anyone is willing to sell you the parts you need.
Old 11-04-2004, 07:50 AM
romine's Avatar
romine romine is offline
I have a 57 chevy and used rotors and calipers from camaro, chevelle and used stock spindles on the 57. Check on classic perform and they give you the exact ones to use. I did this about ten years ago and really helped this boat to stop. Good luck
Old 05-14-2006, 08:18 AM
Rick England Rick England is offline
58 chevy disc brakes
hi i just finshed puting 4 wheel disc brakes on my 58 belair using chevy s-10 brake calipers 1982-1991 and chevy malibu rotors 1978-1982 with a 1977-1979 caddy-seville disc brake rear end hope this helps
Old 05-14-2006, 11:54 AM
joeinblueout4u joeinblueout4u is offline
I used a kit for the brackets and adapter sleeves that I bought from Pioneer Classics in Phoenix, AZ. The rotors and calipers from a '74 Nova worked fine, but even the smaller GM products like the early '80s Cutlass make good donors. I love the stopping power, (I added a firewall mounted power brake setup as well.)
-Joe
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
