Cool. I knew it was a "poly" and not a hemi, but I did not know that the bottom end was based on a 354 Hemi. I thought it would be a cool engine for a rod. Im going to go buy it this weekend. I have to pull it out of the wagon. I might grab the trans just for giggles as well.
It seems I remember the Saratogas came with a wedge motor, not a hemi. The New Yorker and Imperial came with a hemi for '58. A hemi will say FirePower on the valve covers, not spitfire, and a hemi will have the spark plugs way down inside a tube in the middle of the valve covers.
The 354 was a short-term Hemi, being in place for only this one year. The 354 block continued through 1958 using the Polyspheric heads and was called the Chrysler "Spitfire V8". This was used in the Chrysler Windsor and Saratoga models from 1955-1958.
From the above link.
I know it is not a wedge engine. It is a 1958 saratoga 4bbl spitfire engine; still in the car.
I am going to buy it. 310hp and 400lbs torque is impressive for a rare little engine like that.
Son, if it's not a hemi, it's a wedge. It's one or the other. Please don't try to school me on hemis, I was a teenager when those motors were new and have built a few of them.
I wasn't schooling you on anything. I thought a wedge motor referred to the valves/combustion chamber. Spherical chamber is a hemi or poly with canted valves. A wedge is wedge shaped chamber and valves in a straight line. Like the B/RB engines. I always thought it hemi,poly, and wedge.
You may be right. I was just trying to make the distinction between a true hemi combustion chamber and NOT a true hemi combustion chamber. In other words, there is the hemi and then there is everything else that is not a hemi.
The Poly when first introduced was a semi hemi and gradually during its upgrades to increase compression became more of a wedged combustion chamber by the introduction of a cast in quench pad ! I'm one who worked for Mopar and the same bench chatter went around then about the Poly and Hemi ! There is a thread on here that shows pics of the combustion chamber evolution of the poly as it becomes almost a true wedge and then became obsolete and replaced by the wedge engines!
I'd grab it. A highly under rated and very unique engine. The polysphere shares a lot in common with the smaller hemi's, but the head is unique not quite hemi, not quite wedge. Once you've seen one apart you have to ask youself if Chevy engineering had one of these heads when they started to work on the mystery motor aka Rat. The Rat head looks to me like what can be done to a polysphere when you use a stud mounted rocker.
Pretty rare and unique piece of engineering and I'm not a Chrysler guy.
I raced the RED RAM poli years ago, there was a lot of speed equipment available then, now I see a little at swap meets now and then:thumbup: It was a very underestimated engine like oldbogie said :mwink: and it would make a great street rod engine those scalloped valve covers were cool:thumbup:
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
