1958 DelRay - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 09:34 PM
1958 DelRay
i have the chance to buy a VERY nice 1958 Chevy DelRay. The floors have already been done, and there is virtually no rust anywhere except the bottom few inches of the rear quarters, but he is including new metal to fix that. Also comes with some extra stuff. Doors, grills, fenders, dash and a couple other things. Has a 283/3spd. couple questions. all glass is good, chrome is decent.
how much is it worth? (clear title, basicaly needs paint and seats)
how much does it weigh stock? ( i wanna put my TT383 in it, but not if it weighs so much it would be pointless and a waster of HP)
Are the '58 impala and biscayne parts pretty much "swapable"?
Old 01-16-2007, 09:43 PM
It's been a while but I think the rear end is different. I think the chrome on the Impalas swoop in farther around the taillights and there's an extra taillight on each side.
Larry
Old 01-16-2007, 09:53 PM
poncho62's Avatar
Wiki Edits: 5
The chrome is different for sure, the rearend is the same. Some Impalas came with air ride suspension......all were convertibles, I believe.
As for weight, the Delray, if a 2dr sedan, is a quite light model......the lightest model of the bunch. A 4dr would be heavier.
Old 01-16-2007, 10:01 PM
yeah, its a 2 door. any idea on weight even a range would help
Old 01-16-2007, 10:07 PM
poncho62's Avatar
Wiki Edits: 5
Google to the rescue...........
"The 58 Chevrolet
Again, the 'Pathfinder' name like the 'Del Ray' was not carried over for ... Gross vehicle weight 3583 (G.V.W.) etc."
Old 01-16-2007, 11:04 PM
They weren't all verts, for sure there was at least a 2 door hardtop as well and probably other body styles. I cut the roof off a 2 door to make a vert several years ago. The rear end IS different as you can see in these photos. The trunk angles differently and the wings are longer on the Impala to accomodate the extra lights. All that metal on the rear is different. Not that it can't be changed but it's a job.
Larry
Old 01-16-2007, 11:43 PM
You're worried about weight. I think if you look you'll find a modern Firebird weighs close to or maybe a smidge more than that of the 58 Full size car.
Old 01-17-2007, 12:07 AM
46chevyfleetline's Avatar
Last journal entry: A few more
Here's the scoop on the Delray; Was the least expensive. Sold for 2,208 US and weighed 3,347lbs. Model 1241. They make one nice looking ride when done. Thats for sure.
Info from 75 years of Chevrolet.
Cheers
Old 01-17-2007, 05:05 AM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
The Delray has post (2 door Sedan), Impala no post (2 door Hardtop).
I see them sell for as little as 1200, needing work. Finsished they tend to go for 13 to 16 g's.
Mine came with a 327 and I was told that it made the 58 move very well.
If it's a good price sounds like it is an easy fix to get on the road.
EDIT::: You can get just about anything you need at Auto City Classics. They specilize in the 58.
Old 01-17-2007, 05:26 AM
Last journal entry: A few ongoing projects
I did a 58 Biscayne 2 dr Post (I step above the DelRay, and 1 below the the BelAire as far as price and options) in the early 90s. I did mine as a late 50's mild custom and had a 383 with tri-power, TH350 and depending on my mood would run either 3.55 or 3.08 gears.
I would more than hold it's own from stop light to stop light with the 3.55s.
Old 01-17-2007, 06:12 AM
t orzel's Avatar
I have had mine for 30 years now. The suppliers are making more products for these cars. Mine was a drag car from the 60's with a 283 and would run 7.70's in the 1/8 mile. What a wicked sounding motor. Now I have a 348 in it with a turbo 350 and 3.73 gears. Great street car. I am updating the braking and suspension now. http://chevychevy.com/pages/58_Chevy.htm and http://www.bruneauperformance.ca/ are two good places for parts and engine upgrades. There are a bunch more but half the fun is finding them.
Old 01-17-2007, 06:26 AM
poncho62's Avatar
Wiki Edits: 5
Larry
When you said "rearend" I assumed you meant the rear axle................I know the Impalas had hardtops....I meant the air ride ones were converts. BTW, the hardtop and convert were the only body styles for the Impala.......Not that it matters, we are talking about a Delray here.
Old 01-17-2007, 09:04 AM
58Chev's Avatar
Also came as an option on the hardtop.
Exerpt from the following atricle: 58 HardTop W/Level Air
"This model was selected for testing because it is a brand-new one in theChevy lineup and was equipped with the new 348-Cubic-inch V-8 and air suspension."
Old 01-17-2007, 09:21 AM
brian0605's Avatar
mostly confused
Last journal entry:
comment on rear end ratio
As far as the rear end ratio,go with the 3.55 and a 700r4 that is if you pan on going the automatic route. The engine rpm will be about 2000 to 2200 at 70mph and still be really spiffy outta the hole. That's the set up in the car I have posted in my photo album on here. What ever you decide to do the 58 delray is way underrated really a cool old car fixed up. Brian
Old 01-17-2007, 10:05 AM
poncho62's Avatar
Wiki Edits: 5
Stand corrected.The only ones Iever saw were converts......
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 08:36 PM
power steering for 1958 chevy fast454camaro Suspension - Brakes - Steering 14 02-11-2007 11:33 AM
1958 Chevy Biscayne snowjoe Introduce Yourself 1 05-24-2006 01:20 PM
how do i find the blue book value on a 1958 dodge power wagon prstlk General Rodding Tech 4 05-05-2005 02:55 PM
1958 Impala Auto Questions indy_85stariones Transmission - Rearend 8 07-25-2003 11:43 AM
