Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1958 Olds 371 Timing and Vacuum Advance question
Old 08-15-2010, 11:36 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
If one wire was bad, there may be more, but they aren't showing up until power is applied. If it were mine, I would do a complete tune up, points condenser, plugs, wires, and have the coil checked. The timing should be set at the first slot, which is 5 degrees BTC. Centrifical advance should be 24 degrees, at the crank, at 2200 rpm, and maximum vacuum advance should be 24 degrees (crank) at 13-16 inches of manifold vacuum. I hope this gets you going.
Bill
