Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1958 Olds 371 Timing and Vacuum Advance question
Old 08-17-2010, 05:37 PM
gregplus40 gregplus40 is offline
Thank you for the help. I do have a service manual for this car and you are right on with your timing of 5 degrees. I will do some more looking.
The car smokes a lot on start -up, and acceleration, so the plugs are not in the best environment. We are going to look at valve stem seals first, then go from there. I hope we can stop the oil consumption, else wise all the tuning and tweaking will take a back seat to fouled plugs and gas highly mixing with oil for combustion. Thanks again.
