1959 f100 steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2011, 04:43 PM
1959 f100 steering
This truck has a front frame mounted steering box (power ) with pitmen arm shaft running back towards fire wall, attaching to a swing arm .From this arm a shaft runs forward to drag link . Imput would be much appreciated
thanks Gary
questions (1) how effective & safe is this type of steering ?
(2) will I be able to lower the truck by 4 inches as the pitman shaft & lower drag link shaft are approx four inches apart ?
(3) steering column shaft has u joint at fire wall this shaft runs to steering box , the steering box coupler is held on with roll pin and shaft end floats free in coupler , is this acceptable ?
Old 07-30-2011, 03:40 PM
I believe someone has changed the steering box on your F-100
Old 08-09-2011, 11:18 AM
1959 f100 steering
deuce thanks for the reply . I have been away holidaying with grand kids & missed your reply .Back to the steering ,yes your right the steering box was changed to power along with the steering column .The way it has been done , I am not sure it is right with all that linkage to make it work . Also I purchased this truck with out engine or trans , so I have not driven it. I have a donor car (1987 Lincoln town car) with engine & trans .With this truck I would rod it a little lower front & back put some electrical & upholstery changes in .This will be a new type of restore for me & appreciate input.
thanks Gary
F100 steering sector box Moose2 Suspension - Brakes - Steering 4 03-26-2011 09:53 AM
58 ford f100 steering gear box Rome5 Suspension - Brakes - Steering 0 05-31-2008 09:18 AM
65 f100 steering column CJ_F100 Suspension - Brakes - Steering 2 10-11-2007 10:56 PM
1965 f100 steering column ralph grillo Suspension - Brakes - Steering 1 09-27-2005 08:03 PM
Power Steering for 1959 El Camino w/348 bigfred1958 Suspension - Brakes - Steering 0 05-17-2004 09:48 PM
