-   -   1960 235 C-10 trans swap (http://www.hotrodders.com/forum/1960-235-c-10-trans-swap-209990.html)
crusin60s 12-08-2011 04:14 PM
is it true I can put a 5sp tranny off a S-10 chevy? if so, do i need, and can I get any kind of mounting kit for a 1960 235 C-10 with a 4sp granny? thank you
AutoGear 12-09-2011 07:28 AM
you can; its been done, but you may have to shorten the input shaft, and/or use an adapter plate. Hit up Inliners.org and Im sure they can give you some application specific insight if you can't find it here
