1960 235 C-10 trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2011, 04:14 PM
is it true I can put a 5sp tranny off a S-10 chevy? if so, do i need, and can I get any kind of mounting kit for a 1960 235 C-10 with a 4sp granny? thank you
Old 12-09-2011, 07:28 AM
you can; its been done, but you may have to shorten the input shaft, and/or use an adapter plate. Hit up Inliners.org and Im sure they can give you some application specific insight if you can't find it here
1960 c-10 with 235 6cyl, trans swap to automatic? crusin60s Transmission - Rearend 6 09-28-2011 02:32 AM
235 6cyl 1960 pick up manual trans questions crusin60s Transmission - Rearend 5 04-01-2011 03:12 PM
1960 Buick 401 to a T5 Trans 39fordrag Transmission - Rearend 7 11-24-2009 07:00 PM
1960 rear end swap help mittleiderj Transmission - Rearend 4 01-28-2008 03:33 PM
1960 Impala engine swap advice? Stuman Engine 1 11-09-2002 03:47 AM
