1960 389 intake HELP!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2008, 01:03 PM
I have a 1960 389 2bbl.I just purchased a 389 4bbl intake on ebay. I have been told its a bolt on,I have also been told water ports are different.Ive also read the manifolds from 65 and down are the same.HELP!!!! I just want a christmas miracle and my 4bbl to work!!!!
Old 12-24-2008, 02:29 PM
DoubleVision's Avatar
If memorey serves, but don`t quote me on this, Pontiac changed the pattern in 1965, so a earlier intake won`t work.
Old 12-24-2008, 03:39 PM
help!!
the intake I purchased is from a 64 gto. Being that's before 65.....maybe?
(fingers crossed!!)
Old 12-24-2008, 03:54 PM
The date code is B13 3 if that helps!!
Old 12-24-2008, 04:07 PM
woodz428's Avatar
Troll Hunter
From my ancient tech books...it says that Poncho used 3 different patterns...'58-'60,'61-'62 and '65 up. It did say that they will all "theoreticly" interchange if you re-drill and tap the mounting holes. So, while it sounds like you may have the wrong pattern it can be modified.
Old 12-24-2008, 04:35 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Pontiac intake manifold interchange goes like this:
57-58
59-60
61-64
65-79
If you are running the 60 heads, which I assume you are, only the 59 or 60 manifolds are just a bolt on deal.
Old 12-24-2008, 10:49 PM
Ok,what would I have to do to get the 64 manifold to work?It is a 60 motor and heads. I really want to make this work.Drilling/tapping whatever. Any help would be appreciated. And merry christmas to all!!
Old 12-24-2008, 11:09 PM
WDCreech's Avatar
I can't tell you what you need to do, but I will suggest that you put a 59/60 intake manifold gasket up to the manifold, to see what the difference is. An easier route might be to check Ebay or Racing Junk for a correct manifold. I remember a tri power for a 60 on Racing Junk, a while back, and they're more rare than a 4 bbl. You might even get lucky and find a dual quad.
Old 12-25-2008, 11:33 AM
woodz428's Avatar
Troll Hunter
The tech article, a 1970, said that it wasn't really something expected because all series offered the same range of intakes. Of course,almost 40 years later, the choice is not so plentiful. I would do as suggested, and lay the gasket on the manifold. It isn't the porting or water passages according to this, just the attachment points, so it should be fairly straightforward after you compare the 2.
Old 12-25-2008, 04:08 PM
Thanks!! I will try it and keep you guys up to speed! Thanks for all your help!!
Removing intake on SBC... help! v8hed Engine 14 06-06-2008 04:35 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Dart intake? Brodix or Dart Heads? Slowass72 Engine 3 01-20-2004 04:52 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
