I have a 1960 c-10 with a 235 6Cly and 4sp granny. I want to swap the trans to an automatic. any advice? also.what kind of rear end could I use? I would appreciate any advice.
Without an expensive adapter, there is NO auto trans that will just bolt up to the old stovebolt six; you're stuck with either the cast iron Powerglide, or the cast iron, dual range, 4-speed Hydramatic, AKA Hydro. Go to a towing yard auction, and buy a cheap, but good running, Chevrolet with V-8 and auto trans. Then scrap out what's left, along with your old engine-trans.
Swapping the Drivetrain to something newer may be better as suggested above.
Check with >> http://www.wilcap.com/
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
