1960 c-10 with 235 6cyl, trans swap to automatic? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2011, 11:12 PM
trans swap
I have a 1960 c-10 with a 235 6Cly and 4sp granny. I want to swap the trans to an automatic. any advice? also.what kind of rear end could I use? I would appreciate any advice.
Old 09-27-2011, 01:14 AM
SSedan64's Avatar
You could swap in a GM 12-Bolt or Ford 9" Rear, TH700R4 O/D Trans.
What do you plan on using the Truck for Cruising, Street/Strip, Strip only?
Old 09-27-2011, 03:22 AM
willowbilly3's Avatar
Last journal entry: Body mods
Other than finding an original 235 powerglide, I don't think anything else will bolt up without adapters
Old 09-27-2011, 09:22 AM
I think a T5 or a OD 3spd would be more fun; but a 200-4r or 700r4 is certainly easy to do with the proper axle conversion
I have a customer with a similar truck, he went with a 2.98 1st Muncie and a set of 3.31 in a Ford axle (either a 9" or an 8.8 I forget which)
Be careful with adapters, do your research as some seem to be more accurate and easier to install than others
Old 09-27-2011, 09:41 AM
junior stocker's Avatar
Without an expensive adapter, there is NO auto trans that will just bolt up to the old stovebolt six; you're stuck with either the cast iron Powerglide, or the cast iron, dual range, 4-speed Hydramatic, AKA Hydro. Go to a towing yard auction, and buy a cheap, but good running, Chevrolet with V-8 and auto trans. Then scrap out what's left, along with your old engine-trans.
Old 09-27-2011, 08:44 PM
Hey i want to do the same to my truck can anyone show me a website were i can buy an adaptor to hook up a 700R4 to a 6 cylinder engine. Thanks
Old 09-28-2011, 02:32 AM
SSedan64's Avatar
Swapping the Drivetrain to something newer may be better as suggested above.
Check with >> http://www.wilcap.com/
235 6cyl 1960 pick up manual trans questions crusin60s Transmission - Rearend 5 04-01-2011 03:12 PM
61 Rambler Classic, 4.0 jeep swap. or Ford 6cyl? Hellnote1 General Rodding Tech 1 11-01-2010 08:00 PM
Trans swap questions, manual to automatic melton24 Transmission - Rearend 1 10-27-2010 05:12 PM
1960 Buick 401 to a T5 Trans 39fordrag Transmission - Rearend 7 11-24-2009 07:00 PM
nova 250 6cyl to 283 V8 swap 58lincoln Engine 5 09-04-2008 03:29 PM
