1960 chevrolet temperature guage test - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2008, 10:19 PM
The temperature guage pegs 220 after the car runs for a few minutes but the engine is not overheating. The sending unit and thermostat have been replaced but the problem persists. How can I test or find a short. When the sending wire is grounded to the block the gage pegs and when it is removed it returns to 0.
Old 08-12-2008, 07:31 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Is this a stock Chevy gauge or aftermarket?
If stock; it sounds like the gauge is reading incorrectly. If it goes to cold OK, plus climbs steady while heating up without any erratic jumps, it may be something you can adjust.
A lot of gauges have adjustments inside, you would need to remove it to see.
"If" you could find the exact ohms specs in a GM manual, you could test the sender with a meter. The gauge part could be tested with a potentiometer which is merely a "asjustable resistor".
Old 08-14-2008, 08:01 PM
Early model GM gauges should use a 0-30 ohm sending unit, but late model gauges (after about 1965) use 0-90 ohm sending units. Maybe they sold you the wrong GM sending unit at the parts store.
Bruce
1960 Chevrolet Biscayne in need of help. Biscayne Engine 3 10-21-2007 11:37 PM
transmission fluid temperature nixwillys Transmission - Rearend 1 04-16-2006 02:03 PM
Vacuum Guage Test Results.....? (Holley 600CFM)) white66coupe Engine 2 07-15-2003 06:59 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
54 chevy ? pichoboxing Hotrodders' Lounge 11 07-29-2002 07:32 PM
