1960 chevy rear diff - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2006, 01:19 PM
I Need Help In Finding A Diff For A 1960 Chevy Corvette,i Was Told That A Diff From A 1960 Chevy Impala Would Fit.can Anyone Help With This Question
Thanks Bob J
Old 03-21-2006, 02:24 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders Bob...this forum is just for introductions. Please post your question in the Transmission/Rearend forum and you will have a better chance of getting answers. Thanks.
Old 03-21-2006, 06:30 PM
poncho62's Avatar
Wiki Edits: 5
moving it there.......
Old 03-21-2006, 07:15 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I don't have my Corvette book here right now, but a search found that I guessed right, you should have a typical 8.2 inch ring gear, which SHOULD by all means directly swap with the gears of the 60 Impala you inquired about, and several others.
This is a common ring and pinion and new parts are still available for it.
The Impala axle should be similar in design to the ford 9-inch and have a drop out center section (or third member as commonly referred as).
Old 03-21-2006, 07:47 PM
steve t's Avatar
ex biker, now hotrodder
i think they are the same, i have seen some on ebay, i bought a 373 on ebay, it works good
Old 03-21-2006, 08:16 PM
The gears and the third members from 1955 thru 1964 Chevy big cars interchange with 55 to 62 Corvettes. Also 62 and 63 Novas. Suspect the like year trucks too.
Old 03-22-2006, 02:03 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I wasn't sure of the entire third member swapping in to the Corvette, but knew the rest did.
54' chevy rear end gavinpierce Hotrodding Basics 6 02-13-2006 09:31 AM
rear disk brake for newer model chevy truck woodmanscott@hotmail Introduce Yourself 1 12-21-2005 11:53 PM
How to identify the year of a Chevy 10 bolt rear End? frankenvette Transmission - Rearend 2 04-07-2005 10:14 PM
Rear diff swap. g_mac13 Transmission - Rearend 9 01-12-2005 10:42 PM
Jaguar Rear Diff Question Jag Daddy Transmission - Rearend 3 12-23-2003 10:47 AM
