1960 Corvette Pops out of 2nd & 3rd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2012, 02:42 PM
I have a 1960 Corvette with a 4-speed manual transmission. If Iím in 2nd or 3rd hear and I let my foot off the throttle, the transmission pops out of gear. Any suggestions would be greatly appreciated. Thanks!
Old 09-28-2012, 05:20 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
could be a bad input shaft bearing or mainshaft support bearing inside the end of the input shaft. More likely the latter.
Fact is stranger than Fiction
Old 09-28-2012, 05:36 PM
prostreet6t9's Avatar
Differential/Driveline
Don't forget to look for worn shift forks.
Old 09-29-2012, 08:39 AM
302 Z28's Avatar
Worn shift forks, shifter adjustment, worn synchro drums all could contribute to the problem. A complete teardown and inspection is in order.
Vince
The Following User Says Thank You to 302 Z28 For This Useful Post:
FXLong (10-16-2012)
M-22 pops out of 2nd and 3rd Blown 23 T Transmission - Rearend 7 11-30-2011 05:17 PM
700r4 slips from 2nd to 3rd gear scott29 Transmission - Rearend 4 12-07-2008 02:06 PM
delay going from 2nd to 3rd gear aafc Transmission - Rearend 3 12-17-2007 07:54 PM
no 2nd or 3rd gear sik400 Transmission - Rearend 7 07-17-2007 10:14 AM
1st, 2nd, 3rd! No 4th gear Deadtemple Transmission - Rearend 6 10-15-2003 08:15 PM
