Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1960 Ford Falcon Tranny options
Old 03-24-2012, 03:56 PM
matt167 matt167 is offline
Wiki Edits: 31
The early 3spd is the 2.77 3spd. a POS. You can swap it out with a 3.03 3spd from a '66?-later car. There common as dirt and you shouldn't pay more than $300ish for a good 1. V8 trans should also work. you have the right bell as it never changed
