1960 Impala engine swap advice? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2002, 08:53 PM
Question 1960 Impala engine swap advice?
Just picked up a 1960 Impala Nomad Wagon at an impound auction. The original 283 is siezed up. Any body know if a 454 will bolt up easily, if the mounts are in the right place? A friend has offered his recently rebuilt 454 engine for cheaper than rebuld costs for the 283.
Old 11-09-2002, 03:47 AM
BOBCRMAN@aol.com's Avatar
Post
yes the mounts are basically the same as a small block, and it will bolt up to your trans, get the big block as complete as possible ( brackets manifolds etc.) then all you have to fab is exhaust,radiator,linkages.
