1960 impala rear end
tryng to figure out where i can get a ring and pinion kit for this rear end, and axel bearings..i have already got the rebuild kit for the diff. just need the 2 other things. the casting reads:
c 8 0 3725898 GM |
The rear ends from 55-64 are the same gears etc........
where can i find the ring and pinion kit though?and the rear wheel axle bearings
got the bearings and seal for mine thru napa gears came from summit or jegs i think they were richmond gears
u remember how the axle bearing cost??
i think around $50 to $75 installed on the axle with the new seal apiece
its that price per side?
yes it was per side but it was around 5 or 6 yrs ago .also the bearings must be pressed onn and off
Richmond gear has most all you need. |
http://www.show-cars.com/13%20Rear%20End.htm |
i checked them out and they had the ring and pinion, but as far as the rear wheel alxe bearings where can i get those ive looked everywhere no one seems to have them..
thanx ill check it out
Hi,
I just bought an axle bearing through Drake Restoration-on line. They have lots of parts for 55-64 Chevy rears. |
| All times are GMT -6. The time now is 09:07 AM. |
