1960 impala rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2007, 09:34 AM
60n68palaridin's Avatar
tryng to figure out where i can get a ring and pinion kit for this rear end, and axel bearings..i have already got the rebuild kit for the diff. just need the 2 other things. the casting reads:
c 8 0
3725898 GM
Old 12-15-2007, 10:03 AM
poncho62's Avatar
Wiki Edits: 5
The rear ends from 55-64 are the same gears etc........
Old 12-15-2007, 10:49 AM
where can i find the ring and pinion kit though?and the rear wheel axle bearings
Old 12-15-2007, 10:53 AM
59 wagon man's Avatar
got the bearings and seal for mine thru napa gears came from summit or jegs i think they were richmond gears
Old 12-15-2007, 11:15 AM
u remember how the axle bearing cost??
Old 12-15-2007, 11:22 AM
i think around $50 to $75 installed on the axle with the new seal apiece
Old 12-15-2007, 11:44 AM
its that price per side?
Old 12-15-2007, 11:56 AM
yes it was per side but it was around 5 or 6 yrs ago .also the bearings must be pressed onn and off
Old 12-15-2007, 02:44 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
c 8 0
3725898 GM
hey just a quick note...3.08-3.70 uses the same case and the 4.11 on up has a different case. Otherwise depending on your current ratio you may need a ring gear spacer.
Richmond gear has most all you need.
Old 12-15-2007, 03:03 PM
1930u's Avatar
c 8 0
3725898 GM
this is probably the best place for the parts you need.
http://www.show-cars.com/13%20Rear%20End.htm
Old 12-15-2007, 03:06 PM
i checked them out and they had the ring and pinion, but as far as the rear wheel alxe bearings where can i get those ive looked everywhere no one seems to have them..
Old 12-15-2007, 03:13 PM
thanx ill check it out
Old 12-15-2007, 03:49 PM
1930u's Avatar
Show Cars by Brad Ranweiler wil have what you need...thats the link I provided. If for some reason their out of stock Kanter Automotive should have then too. Just google Kanter.
Old 12-15-2007, 04:44 PM
Thirty Seven Ply's Avatar
Hi,
I just bought an axle bearing through Drake Restoration-on line.
They have lots of parts for 55-64 Chevy rears.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
Rear end ID ctown Transmission - Rearend 1 05-15-2006 10:20 AM
What kind of rear end does my 64 Impala have? Uber Transmission - Rearend 8 07-17-2004 07:00 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
