Originally Posted by 60n68palaridin
tryng to figure out where i can get a ring and pinion kit for this rear end, and axel bearings..i have already got the rebuild kit for the diff. just need the 2 other things. the casting reads:
c 8 0
3725898 GM
hey just a quick note...3.08-3.70 uses the same case and the 4.11 on up has a different case. Otherwise depending on your current ratio you may need a ring gear spacer.
Richmond gear has most all you need.
