I recommend a 4 series Eaton Posi and a 3.73 gear for the truck 12 bolt. It's a stronger rear end than the 8.5 and it already fits your truck. Don't forget to get a good installation kit with the Eaton and gears.
Forgot to mention that you will probably need a set of axles for that rear end. I think those had the weak 17 or 19 spline axles and you need to upgrade it to 30 spline axles.
What size are the tires on the truck? If you have really tall tires a little more gear.Decide how much high way driving you will be using the truck for and the RPM that you can cruise at with out going crazy. 3.73 is a good place to start your calculations. 62 mph =2700 RPM with 29 inch tall tires,,,62 MPH=3200 RPM with 25 inch tall tires
The 12 bolt usually showed up around 64/65. Maybe you already have a newer 12 bolt?
Might be a good idea to pull a axle and get a spline count and length? As BGH said the early ones have course spline axles. |
That's why I'm here asking questions. I'm looking forward to bringing this thing to some events but I don't want to have to worry about breaking stuff and getting stranded. If I take it easy on the pedal, will I get by with my 3.08 12 bolt open rear or would the 8.5" 10 bolt 2.41 posi be a better choice until I can afford a 3 series posi unit for one or the other?
A good way to launch is steeper gears. The 700r4 over drive auto has a lower first gear for better launch.A longer stroke engine can make more torque at lower RPM for a better launch.
You just need to do the math of what you have and what you need to make the performance goals you need. |
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
CHEVILLAC (01-17-2013) | ||
Keep the 12 bolt. The 8.5 has 28 spline axles and the gears will completely suck. If you want to keep the 3.08 gear then you will need a 3 series posi for it, but I don't think you will like the 3.08.
| The Following User Says Thank You to big gear head For This Useful Post: | ||
I'd use the 12 bolt if it was me. 342 or 373 ratio with a good posi.
Instead of thinking of a 700 trans.. I'd save up the money and just do your diff with good parts. 308's will be a little doggy but it will get ya by while you save up. |
| The Following User Says Thank You to prostreet6t9 For This Useful Post: | ||
Ok, I've been doing a ton of reading and have come to the conclusion that a '79 8.5" 10 bolt with 28 spline axles is stronger than a '73 8.75" 12 bolt truck with 28 spline axles because the pinion shaft diameter on the 10 bolt is bigger than the 12 bolt. The only other difference I can find between the two besides ring gear diameter and track width is parts availability and interchangability. Parts for the 10 bolt are more interchangable as well as cheaper and easier to find, especially in a posi application. So when I can save up some money and get a 3 series posi carrier and 3.73 gear set for the 10 bolt, I'll adapt it to fit under my truck. I have trailing arm/airbag rear suspension so getting the 10 bolt to mount up will be a breeze. I don't mind the narrower track width since I'm going to run cheater slicks, that means I can get wider tires. In the meantime I just have to hope the 3.08 open rear will hold up. You guys think it will hold up to 400hp or so, or should I go easy on the pedal (which won't be easy)?
| Changing My Rear End gears ...chevy truck | bosco200 | Transmission - Rearend | 14 | 06-28-2009 07:37 PM |
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
| 65 Chevy Rear End Gears | mweber | Engine | 3 | 01-03-2004 04:05 PM |
| rear end width - 1961 chevy | 61wagonair | General Rodding Tech | 1 | 12-05-2003 05:37 AM |
| 1961 C20 Rear End | Ralbon | Transmission - Rearend | 3 | 08-29-2003 04:14 PM |
