Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1961 electrical problem
Old 03-09-2008, 03:51 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
Yes your grounds need to be on a clean unpainted surface. Your ignition wire might be on the wrong post either at your starter solinoid or perhaps at the ignition switch. It might be a good idea to re-read your instructions on your harness kit and re-check them.
