Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1961 electrical problem
Old 03-12-2008, 05:23 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Originally Posted by barflymark
the 12 volt start wire from the solenoid is right, it sounds like you have no 12 volt run circuit. either at the ignition switch or the voltage resistor before the coil. when the stater engages it sends 12 volts to directly to the coil. when you let up on the switch you should have 12 volts to the resistor and about 8 volts out of the resistor.
The brown wire should have a cycling voltage on a test light. in other words it blinks on and off on a trst light. if it is steady the voltage regulator for the gauges may be shorted.
Not to make you angry, but that info is incorrect I hate to see someone pull their hair out trying to trace a problem, using wrong test info. Hope you are not offended.
The resistor can show a full 12.5v (engine off), "IF" the points are "open". (if he has the stock points-type dist) An ignition resistor will not resist voltage if there is no load on the wire.
Also, the ignition resistors don't "blink". You are referring to a voltage limiter used on some brands of cars that only feed the gauges.
