Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1961 electrical problem
Old 03-13-2008, 02:38 AM
malc's Avatar
malc malc is offline
Living At The Speed Of Life
This condition usually results from wiring the Ignition System to an “ACCESSORY-SWITCHED ON/OFF” rather than “IGNITION-SWITCHED ON/OFF.
Check to see if your accessory circuits are live in the “RUN mode” and dead when the Ignition Switch is in the “START" mode.
