1961 ford falcon electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2012, 05:45 PM
I posted about thh ability to swap out my vacuum pump/ fuel pump combo pump for a straight up mechanical only fuel pump. plan b is a small electric fuel pump and blank out plate where the manual combo pump previously bolted to the motor. any input really didn't want to go this route but the guy I work with use to be toyota mechanic and swears the electric fuel pump set up will be way more reliable. Any ideas input would be greatly appreciated. I really just want my falcon to be more reliable so I can drive it more often and further
Old 02-09-2012, 06:10 PM
EOD Guy's Avatar
Mech fuel pumps have been used for years with great results! Now there are some problems.... vapor lock etc..... but there are also problems with elec pumps.... regulator, noise level, safety shut-off, etc..... bottom line... use what you desire, both systems, when sound, are reliable.
Old 02-09-2012, 06:43 PM
Wiki Edits: 31
just be warned without the vac pump, the vac wipers wont work well, and you'll need the electric setup from a '62-'63 Falcon.. As far as the fuel pump, just get 1 for a 1963 Ford Falcon 6cyl with electric wipers. Dont overcomplicate the system if you dont need to
falcon fuel pump question 61falcon Engine 1 02-04-2012 08:13 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Electric fuel pump for my 37 Ford?? APalusky Engine 8 11-28-2006 05:54 PM
electric fuel pump vapor locks on Ford V8 ? junkyard junkie Engine 9 04-03-2006 09:17 AM
