1961 hydromatic help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2007, 08:23 PM
i have a 1961 Oldsmobile with a 394ic v8 and a hydromatic trans when im just cruse'n and it goes to change up the revs drop/ studder then it changes. iwas told by a friend i need a new torque converter. i wanted to know what torque converters will fit it?
thank you
miles
Old 05-30-2007, 08:46 PM
Will I ever get it done?
Last journal entry: Passenger Door
Your hydro doesn't have a torque converter. It has a fluid coupling. Sounds like internal problems either in the friction material or the valving.
Old 05-30-2007, 09:00 PM
1961 hydro_madic
thanks for that-so im guessing the only thing for it is a rebuild?
Old 05-30-2007, 09:33 PM
Crosley's Avatar
Wiki Edits: 1659
Originally Posted by rocketman61
i have a 1961 Oldsmobile with a 394ic v8 and a hydromatic trans when im just cruse'n and it goes to change up the revs drop/ studder then it changes. i was told by a friend i need a new torque converter. i wanted to know what torque converters will fit it?
thank you
miles
I believe you have a model 10 roto hydramatic....... often called a Slim Jim
Your tranny may be shifting correctly..... these units did not shift in the same manner as more modern trannys .
I ran around with a friend in high school with a 62 Olds Starfire with 394 engine that had one of these old trannys . It shifted as you describe
Old 07-25-2007, 07:35 PM
I would swap in the 400 Turbo. The Slimjim is trouble.
Old 07-25-2007, 07:54 PM
Crosley's Avatar
Wiki Edits: 1659
that would require an expensive adapter for the t-400 to fit a 394 Olds motor
Old 07-26-2007, 05:30 AM
slimjim
I believe Crosley is correct, as best as I remember [ this being a slimjim and working correctly ].
Later today I will call the man that taught me my trade [ he's a much older trans rebuilder, now retired] and I'll check with him about this.
And of course will post his info.
Old 07-26-2007, 06:56 AM
The price of the adapter is well worth it for the benefit of having the Turbo 400. The Turbo 400 takes a block mounted starter.
I would contact Wilcap and have one made.
http://www.wilcap.com/webdoc8.html
I've had cars (63 Olds 88, 64 Catalina and 421 Grand Prix) with Slim-Jims and all that transmission was good for was making transmission shops rich. Besides have you looked at the price to rebuild a slim-jim? There's no other way to go.
A friend recently put a working slim jim behind a healthy Pontiac 462 just for kicks. It lasted about 100 miles. He is putting the much stronger 4 speed Super Hydromatic in his Catalina now.
I have a 64 Bonneville with a stout 462 with a 64 Jetaway 4 speed hydro and its a fantastic combo. I wouldn't want any other tranny. The 4 speed hydro with its 3.97 first coupled with a 2.56 posi is a fantastic street combo.
I also like cruising at 65 mph @ 2100 rpm.
I'm getting ready to install a governor from a 60 Pontiac Tri-Power 389 to extend the rpm range.
Name:	finished engine.JPG
ID:	22954   Click image for larger version
ID:	22955   Click image for larger version
Name:	videos north park 001.JPG
ID:	22956   Click image for larger version
1961 Chevy Bel Air emerald.mirror Introduce Yourself 4 02-03-2006 07:47 AM
Steering modifcation to 1961 Buick Invicta rfowler Suspension - Brakes - Steering 3 11-03-2005 11:01 PM
Retrofiting 1961 Buick Invicta rfowler Introduce Yourself 2 01-27-2005 02:18 PM
1961 Impala rear quaters Impalass64 Body - Exterior 2 10-01-2002 04:00 PM
1961 Apache IFS Conversion ChevyLuv Suspension - Brakes - Steering 6 09-15-2002 10:31 AM
