1962 chevy pickup - Oil leak between canister and block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2008, 01:24 PM
I have been helping my grandfather get his dad's (my great grandfather) 1962 chevy c10 6 cylinder running. We have gotten it going, but there is a leak in the hose that goes from the oil filter/canister to the block. I can't seem to find a replacement hose for this anywhere. any ideas? is there very much pressure in this hose?
is there an adapter for this model of engine/truck to use a newer style spin-on filter?
Thanks,
Shad
Old 01-16-2008, 01:47 PM
31 five window
Last journal entry: grill and rear end
Think about it, The pressure in the hose is equal to your oil pressure. I believe a grease gun hose is the same thread and oil resistant and can hold a lot more pressure than the approximate 35 PSI that your engine should have. Hope this helps.
Old 01-16-2008, 01:56 PM
427feracer's Avatar
First On Race Day
This might help your oil problem!!
Hey, There is a filter relocator kit at Summitracing.com that would solve your problem. I would definetly recommend summit to any aspiring engine builders and I would definetly go there if i were you for your preformance parts if you decide to biuld a quality high power engine OK.
Your friend
427feracer
Old 01-16-2008, 01:57 PM
thanks for the idea! would the inner diameters be close when comparing the oil hose and a grease gun hose?
thanks,
Shad
