1962 Ford Falcon 8 inch Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2008, 05:20 PM
Last journal entry: 1932 Chev 2 Door Sedan
Hi,
I have a chance to buy an 8" rear end out of a 1962 Ford Falcon for $50.00. I plan to use a 302 engine and 8" rear in my 1928 Ford Tudor.
Questions: Will it fit? or might it be too wide for the full fendered 28 Tudor?
What should I look at when inspecting that 8" rear? Is it a good deal and what are the gear ratios likely in that rear end (assuming it is all original still)?
What transmission would be a good mate with the 302 and the 8" rear? ( 5 speed or automatic?
Thanks
Merki
Old 09-11-2008, 06:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by Merki
Hi,
Thanks
Merki
1962 Falcons were not built with 8 inch rear differentials.
I would find out where this 8 inch diff came from. perhaps measure the diff for fitment.
I would suspect the 8 inch diff would be from a Maverick Ford car.
Old 09-12-2008, 03:05 AM
3rdmember
what did the V-8 falcoons use?
could it be from a 63 or newer?
just athought, the tag on the rear will tell the tale.
for 50 bucks, i'd buy it anyway...
Old 09-12-2008, 06:27 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the tag was on the diff or any code off the rear diff.
A visual of the diff would help too.
an 8 inch differential with a mild 302 would be a great setup.
Old 09-12-2008, 06:35 AM
woodz428's Avatar
Troll Hunter
As pointed out there wasn't an 8 inch in a '62 Falcon, it may be one pulled from a Mustang ('65-'66), but it may be just a regular old 6 cylinder rear. An 8 inch looks much like a shrunken 9". If it is an intregal carrier rear, it's not one to get. Posting a pic as suggested would help in identifying. I have people try to sell me things that aren't what they believe on a regular basis. Most times it's because they have been told by someone else what it "is", the uninformed educating the less informed....a buyer beware area for sure. If it has 5 bolt axles, that's a positive indicator...unless they have been drilled.
Old 09-12-2008, 08:42 AM
onebadmerc's Avatar
I need a bucket of arc sparks
If it is a pre 68 8" rearend they will have a tapered 28 spline axle with I think, (not 100% sure) four vertical ribbed case. The post 68 cases are much stronger and will have 28 spline non tapered axles.
Old 09-13-2008, 09:17 PM
72 grabber 51F-1 65 chevystang
Is it 4 or 5 lug? I'm thinking 7.5 rear but not sure. 8" inch rears in mavericks came with 2.79 and 3.00 gear ratios but you can get about any ratio you want
Old 09-13-2008, 09:50 PM
Wiki Edits: 31
if it is the original '62 rear, it would be a 7 1/4" with 4 lugs.. but a 'Maverick 6cyl rear end ( bolt in ) is a 4 lug 8".. '65 6cyl Mustang has an 8" rear, with 4 lugs, and is special/ desirable to use, but I can't remember what is special about it.... all of these rear ends could fit the Falcon, and if it has been mod'd, just going to have to check
Old 09-13-2008, 09:53 PM
If the falcon is going to be a parts car I would look for a 5 lug 8 inch since you can get a lot better choice of wheels
Old 09-13-2008, 09:58 PM
Wiki Edits: 31
just have to swap the axles with 5 lug axles... because of the popularity of the Maverick rear, they are being produced
Old 09-13-2008, 10:01 PM
I never thought about that. I fool with mavericks so I have plenty of 8 inches and never thought about swapping axles
Ford 9" Rear End 66Moostang Transmission - Rearend 4 05-17-2008 05:06 PM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
ford rear end help lolathemustang Transmission - Rearend 11 01-08-2006 05:55 PM
Ford Pickup Rear End Kaylah Transmission - Rearend 6 05-09-2003 03:14 PM
