1962 impala rear end choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2014, 12:13 AM
hello
having a 1962 impala
i dont yet what kind of engine I will put in it , but for sure i want some hp
i will drive it as daily driver , no drag racing at all
now my wondering is more about the rear end ..
keep the original with the original gears and axle ???
make it stronger ? better gears and axle?
use a 9 inch ford? ( this sound expansive....)
find a use 9 inch ? ( wich one )
find a 12 bolts ?( wich one )
i can do some metal work and welding
if anyone have done on impala that let me know , i like better the do it my self than buy every thing new
thankks
Old 02-02-2014, 01:05 AM
Banned
K.I.S.S. USE whats under it for now.. upgrade if needed down the line
Old 02-02-2014, 05:49 AM
jokerZ71's Avatar
Wrench Turner
Choose your rearend after you decide on engine & transmission.
Old 02-02-2014, 10:17 AM
ok but if later for one reason i need to upgrade it ?
Old 02-02-2014, 11:44 AM
Northstar T's Avatar
Gone sailing
I've had a bunch of cars with the 57-64 rear end under them (55-56 are weaker). I wouldn't say they're bulletproof by any means, but there's a lot of newer rears not as strong. for a street cruiser… use the one ya got.
.02
The Following User Says Thank You to Northstar T For This Useful Post:
Vincentnova (02-02-2014)
Old 02-02-2014, 12:15 PM
big gear head's Avatar
High Performance Rear Ends
There are parts available for the '55-'64 8.2 rear end that make it stronger. IT might not be cheap, but it would be easier than building another rear end.
The Following User Says Thank You to big gear head For This Useful Post:
Rear end gear choice gvasquez_81 Hotrodding Basics 12 09-08-2013 05:00 PM
rear end choice for a 66 skylark Bad66 Transmission - Rearend 2 07-25-2012 01:09 PM
1962 Ford Falcon 8 inch Rear End Merki Transmission - Rearend 10 09-13-2008 10:01 PM
trans and rear end ratio choice? bonzipenguins Transmission - Rearend 7 05-08-2006 07:35 AM
66 Impala rear end fsiramps Transmission - Rearend 2 02-12-2003 01:59 PM
