1962 olds f-85 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2008, 07:47 PM
1962 olds f-85
what other trans. will bolt to the aluminum v-8 besides the Slim Jim ?
Robert
Old 02-07-2008, 07:19 PM
Wiki Edits: 27
trans bolt up
If I rememger right there were factory bellhousings for the baby buick, olds and pontiac engines to use the old t 10 4 speeds and other trannys with the chevy pattern
Old 02-11-2008, 08:50 AM
The aluminum 215 has a unique bellhousing bolt pattern. Only bellhousings for that engine bolt up. D&D Fabrications in Michigan builds adapters for later model GM automatics.
http://www.aluminumv8.com/
Also, the Rover versions of this engine use the same bellhousing. You might be able to adapt one of those transmissions.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
S10 to '49 Olds? grouch Suspension - Brakes - Steering 100 10-22-2010 04:57 PM
HELP: Olds 350 swap in a 85 Regal Torx Engine 3 04-12-2006 04:55 AM
85 Olds to Chev fan shroud problem oldsmo Engine 4 03-26-2006 09:45 AM
403 olds in 85 toyota celica toymobile Engine 5 01-01-2003 05:05 PM
