I guess you are going to have a rear end built to fit the truck? I would start with a 9 inch truck housing. They are pretty wide and can be narrowed to fit your truck. The truck housings are the strongest and many times you will get a Traction Lock differential and 31 spline axles in a truck rear end. But why not just build a 12 bolt Chevy truck rear end for it? The 12 bolt is plenty strong for what you are building. The 12 bolt is lighter and takes less power to trun, and it will be a lot cheaper to build.
^^ Agree whole heartedly.
On the street with that engine trans combo, you'll be fine. You may even invest in one of these: |
here is a guide for picking a rearend, might help. scroll down to the bottom
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| S10 Rear End in a 33 Chevy | TFoch | Transmission - Rearend | 2 | 02-04-2007 02:08 PM |
| How to identify the year of a Chevy 10 bolt rear End? | frankenvette | Transmission - Rearend | 2 | 04-07-2005 10:14 PM |
| 1978 chevy truck rear end gear ratio? | gpeak | Transmission - Rearend | 2 | 11-25-2003 11:54 PM |
| Rear end swap for '53 Chevy truck | Bruce H | Transmission - Rearend | 4 | 12-01-2002 11:43 AM |
