1963 Ford 352 Marine Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2012, 01:14 PM
hello,
I am new to this forum and have a ford 352 240 hp interceptor marine engine (RH rotation looking from rear)with a burnt valve (#2 cylinder). Rather than pulling the heads I am thinking of purhcasing a long block and transferring all needed parts from the 352.. Questions:
1. can I purchase either a 352 or 390
2. regardless of what I purhcase do I need to use my old cam?
Note: I am trying to minimize costs .
thank you
Old 06-20-2012, 01:47 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You need to have the proper cam and given the age of what you have a new cam and lifters should be part of your rebuild plan...
Sam
Old 06-20-2012, 01:53 PM
Externally, a 352 is the same as most any other Ford FE engine. This engine was made as a 332, 352, 360, 390, 406, 410, 428, and 427. Truck versions of this engine were 361, and 391. There was also an OHC 427, with about ten feet of timing chains.
Rotating clockwise, viewed from the rear, is a reverse rotation engine. The engine has a reverse grind camshaft, and the distributor is also different. Additionally, if the pistons have offset piston pins, they may be installed differently to accommodate reverse rotation.
Probably the cheapest way to just get it running again is to pull the heads, and do a valve job. But that may not be a good idea if the piston rings are worn.
Old 12-29-2012, 03:40 PM
Ford 352
I would like to know if you still have ************
Dave*****************8
Last edited by 68NovaSS; 06-23-2013 at 08:35 PM. Reason: belongs in classified ads or by PM
Old 06-23-2013, 01:29 PM
Ford 352
I am looking for *******************
Last edited by 68NovaSS; 06-23-2013 at 08:35 PM. Reason: Can't you read the last post edit? Not allowed
Old 06-23-2013, 04:31 PM
Banned
oh my. you have just given the crooks out their in cyberspace all they need to steal your life! Let alone all the spam in you email , Also late nite phone calls! What are you thinking??? The mods removed this info once. They may not help you again
Convert 1963 352 FE to 390 FE 1963galaxiexl Engine 2 05-19-2012 11:20 PM
1963 ford fairlane engine v.i.n code? clint31nky Engine 4 09-01-2007 01:29 AM
Ford 352 bigdoggcif Engine 5 10-17-2006 05:19 AM
352 and 390 ford.. zcxtmi Engine 5 08-11-2006 04:58 PM
FORD f100 352 "SLOWMOE" Engine 1 01-23-2005 06:11 PM
