1964 chevy belair powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2012, 10:09 PM
Hey there folks. I just purchased a 1964 Chevy Belair with a inline 6 cylinder and an aluminum powerglide transmission. My question is that there is a large hole about 2 to 3 inches across in the left side of the bellhousing, I am wondering if that is a cooling hole or something? There is no oil cooler lines on this transmission, just a cooling disc or fan behind the torque convertor. Another ? is that I am putting a 1964 327 in this car, will I run into any problems with this combo? i am only gonna use this car for cruising and shows. Thanks in advance.
Old 01-02-2012, 11:00 PM
pricesgarages's Avatar
the holes are for cooling you should be ok with it for a crusiser but id look into s th350 or 700r swap in the future
Old 01-03-2012, 01:51 AM
junior stocker's Avatar
The air cooled Glides utilized a torque converter with a shroud tack welded to it, the turbine cover assembly, and the 4 cooling holes in the bell. Should be fine for your anticipated style of driving, but you can always add a fluid cooling trans cooler to the setup. At the very least, stick a steel direct clutch hub in it and use a 5 pack clutch, along with a shift improve kit. BUT, Glides are still boring on the street, and you'll be happier with a TH350.
Old 01-03-2012, 10:01 AM
cooling hole
Thats still a cooling hole even if its one that big...2 to 3 inches...just wanna know that someone didnt hack a hole in it. Thanks folks!
Old 01-04-2012, 12:16 PM
Yes, and there are actually FOUR cooling holes in the bell. The first air cooled aluminum Glides had rectangular holes.
my 55 chevy 2dr ht belair paulsoluri Introduce Yourself 2 12-19-2011 10:04 AM
65 chevy belair DeaconJ Hotrodding Basics 4 10-30-2009 07:32 AM
1964 Belair transmission swap - Turbo Thrift for t350? hot_rod_kid Transmission - Rearend 19 05-25-2009 03:46 PM
66 Chevy BelAir byron74 Introduce Yourself 2 02-10-2009 01:04 PM
53 Chevy Belair chevypop53 Introduce Yourself 1 03-02-2008 11:20 AM
