1964 chevy c10 please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2011, 10:56 PM
i need to figure out how to tighten up the parking brake on my 1964 chevy c10??? i bought the truck but i need to fix the parking break because it doesnt tighten or work apparently.. can any one please give me some ideas of what i need to do...
Old 05-30-2011, 06:24 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
First check the cables under the truck, most likely they are stuck/rusted. Part of the cable will be exposed, part runs through a semi rigid outer housing.
You will need some help, someone to work the parking brake while the other person is under the truck observing the operation of the cable.
If it is stuck, you might be able to work it free, most likely the enclosed sections will have to be replaced. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=89
The adjustment is done where the cable that exits the cab "T's" with the cable that operates the parking brake. The attached link shows the proper routing of the cable system.
If the cables are free and easily move, check the rear brake shoes for proper shoe friction material thickness and proper adjustment before adjusting the cable itself.
1964 chevy k10 redneck1964k10 Hotrodding Basics 8 06-17-2010 10:51 PM
1964 Chevy Pickup wiliweld Introduce Yourself 1 07-28-2009 10:16 PM
What Trannys Fit 1964 Chevy c10? 64chevybeater Transmission - Rearend 4 06-13-2009 04:40 PM
1964 chevy truck Brian Makray Introduce Yourself 1 06-24-2006 01:39 AM
1964 Chevy Impala flip31277 Introduce Yourself 1 06-17-2006 10:50 AM
