Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1964 Chevy II , 700r4 vs 200r4 with V8 ?
  #19 (permalink)
Old 01-11-2013, 05:07 PM
cadillacdave1 cadillacdave1 is offline
You will definitely have to change the rear end gears with either transmission. The 700R4 has a 3.06 first gear to get the car moving so you don't need really steep gears in the rear. But a 3.08 gear won't work well with the overdrive, you will be at 1,400 RPM on the highway. A 3.55 or 3.73 gear will work fine with that combo. The 400 motor will make plenty of torque down low so the 3.55 be the best bet. Good luck with the build.
