1964 Chevy Nova Rear End Swap / Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 07:52 PM
I just installed a 350 v8 in my '64 Nova. I currently have an 8.2" 10 - bolt rear end. I do not have any experience with rear-ends but am wanting to convert / swap to a posi track rear. Is there any way to convert the rear that is already on it to posi or do I need to swap out the entire rear?
Old 02-12-2012, 07:09 AM
SSedan64's Avatar
Yes, you can add an Eaton Posi, Yukon DuraGrip Posi, Detroit TrueTrac Posi etc.. to the existing 8.2" Rear.
Upgraded Axles, Diff Girdle/Cover etc.. are also available.
Use the "Diff Wizard" >> http://www.ringpinion.com/
Old 02-12-2012, 08:15 PM
I had a 62 Chev II and the center section was the same as 55-64 Full size Chevy's. Problem was 4 bolt wheels.
51 chevy truck with nova rear 51 chevyt Transmission - Rearend 3 05-05-2011 05:36 AM
Nova Subframe Swap into 47 Chevy Car??? jim1fun1 Suspension - Brakes - Steering 3 04-23-2011 07:23 AM
1971 Nova rear drum to disc conversion. 1971 Nova Suspension - Brakes - Steering 5 12-12-2006 04:07 PM
rear end 1964 nova mkn Transmission - Rearend 2 08-16-2006 07:59 AM
56 Chevy Bel-air 150 Disc Brake Conversion/Swap heavy2dachevy Suspension - Brakes - Steering 1 07-03-2006 02:40 PM
