-   -   1964 F100 Disc Brake Conversion (http://www.hotrodders.com/forum/1964-f100-disc-brake-conversion-106148.html)
Charlse P. Green 01-07-2007 08:13 AM
I have a 1964 F100 and I want to convert to front disc brakes. I have a 1984 F150 from which I will transplant the drive train from and to the 1964. Can the 1984 disc brake system be installed in the 64? If not is there another model year vehicle disc brake system that I can use? Or to I have to buy a conversion kit?
Charlse
Deuce 01-07-2007 07:22 PM
:welcome: WELCOME to Hotrodders.com :welcome:
With your truck being a straight axle front end truck and the donor being a different design ... I doubt if they interchange ... but I could be mistaken ... As a Moderator here I wanted to WELCOME you here ...
Deuce ... Moderator
Charlse P. Green 01-08-2007 06:44 PM
I appreciate the welcome and your advise, Thank you.
I hope to have the 64 the garage soon and then I can have a first hand look but I thought I would throw the question out there in the meantime.
Cheers
Charlse
poncho62 01-08-2007 07:17 PM
How about swapping the 64 body onto the 84 frame...........I would do some measuring and see how feasable that is.
Charlse P. Green 01-09-2007 04:57 PM
I had not considered swapping the body, certainly worth considering. That would take care of the power steering too. Thanks for the suggestion.
jisbell 01-14-2007 10:09 PM
disc brakes
1973 to 1979 same steering box location-get the whole disc brake setup -plus m/s and brake lines-king pin same dia.-use brass bus.-hone to fit king pins-notch pin to fit straight axle-check tie rod end dia.- :)
