Hotrodders Bulletin Board
#1
1964 F100 Disc Brake Conversion
I have a 1964 F100 and I want to convert to front disc brakes. I have a 1984 F150 from which I will transplant the drive train from and to the 1964. Can the 1984 disc brake system be installed in the 64? If not is there another model year vehicle disc brake system that I can use? Or to I have to buy a conversion kit?
Charlse |
#2
re: 1964 F100 Disc Brake Conversion
WELCOME to Hotrodders.com With your truck being a straight axle front end truck and the donor being a different design ... I doubt if they interchange ... but I could be mistaken ... As a Moderator here I wanted to WELCOME you here ... Deuce ... Moderator |
#3
I appreciate the welcome and your advise, Thank you.
I hope to have the 64 the garage soon and then I can have a first hand look but I thought I would throw the question out there in the meantime. Cheers Charlse |
#4
How about swapping the 64 body onto the 84 frame...........I would do some measuring and see how feasable that is.
#6
disc brakes
1973 to 1979 same steering box location-get the whole disc brake setup -plus m/s and brake lines-king pin same dia.-use brass bus.-hone to fit king pins-notch pin to fit straight axle-check tie rod end dia.-
Back to top |
Similar Threads for: "1964 F100 Disc Brake Conversion"
| drum to disc conversion kits | dmented | Suspension - Brakes - Steering | 4 | 06-06-2007 09:06 PM |
| Corvair Disc Brake Conversion | tcruise | Suspension - Brakes - Steering | 3 | 08-31-2005 12:16 AM |
| Ford Galaxie Disc Brake Conversion | CrashFarmer2 | Suspension - Brakes - Steering | 2 | 12-07-2004 11:35 AM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
