Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1964 F100 Disc Brake Conversion
Old 01-14-2007, 09:09 PM
jisbell jisbell is offline
disc brakes
1973 to 1979 same steering box location-get the whole disc brake setup -plus m/s and brake lines-king pin same dia.-use brass bus.-hone to fit king pins-notch pin to fit straight axle-check tie rod end dia.-
