1964 Falcon & Unisteer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2010, 09:21 AM
I have 1976 Granada Disk brakes on the front of my 1964 Falcon and installed a new Unisteer Power Rack system. My problem is the turning radius is very short. Has anyone used this and if so what spindles did you use? I called Unisteer and they said they used Disk Brake adapters on the original spindals for the mock up. It seems the connecting arms on the spindals are to long on the Granada ones. I used these since I was also converting from 4 lug to 5 lug.
Old 10-20-2010, 06:09 PM
LATECH's Avatar
can you put on the old spindles? will the rotors/bearings from the granada fit?and if so maybe you can buy brackets to hang the calipers on so you can use the falcon steering arms
Old 10-20-2010, 06:13 PM
LATECH's Avatar
Look Here
http://www.fordfalcon2000.com/restor...discbrakes.htm
I think you will find what you need here.
Old 10-20-2010, 08:36 PM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by onefalcon
...My problem is the turning radius is very short...
Can't say I ever heard anyone complain of the turn radius being too short! If I may ask, why is this bothering you?
Russ
Seating Unisteer u joints on rack and pinion 001mustang Suspension - Brakes - Steering 4 08-29-2010 11:38 AM
Falcon bumper swap.. Blackhauk90 Body - Exterior 1 09-24-2007 08:21 PM
HELP!!! 1964 Falcon BACNAR Suspension - Brakes - Steering 2 07-04-2007 02:11 AM
1964 ford falcon xm falc64 Introduce Yourself 18 12-08-2004 07:07 AM
1964 Ford Falcon Trans slip into 2nd whytyewytche Transmission - Rearend 0 11-27-2001 06:13 AM
