Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 08-21-2002, 07:39 PM
56don 56don is offline
New Member
Post 1964 Ford brakes
Has anyone here put disc brakes on the front of a 1964 Ford Galaxie? I am trying to find out what kind I can adapt without using some aftermarket kit that you can never find replacement parts for.
  #2
Old 08-22-2002, 02:26 AM
KULTULZ KULTULZ is offline
aka Duke of URL
Thumbs up
The Granada/Monarch (Maverick/Comet) seems to be the most popular. Single piston sliding caliper.
Old 08-22-2002, 04:52 PM
New Member
Post
I put Granada brakes on a 67 Fairlane and they work great but the suspension is different on the 64 so I don't think Granada style will work.
Old 08-22-2002, 07:52 PM
aka Duke of URL
Post
They need to be reworked to accept the '64 ball joint taper. <a href="http://www.fatmanfab.com/" target="_blank">-Fatman Fabrications-</a> sells a set reasonable.
There are other options. The '65/'66 Bird came with four piston Kelsey-Hayes or you can adapt from a later Galaxie/LTD.
Old 08-23-2002, 11:51 AM
DragLinkscc's Avatar
DragLinkscc DragLinkscc is offline
New Member
Thumbs up
We are doing a swap over on a 64 comet and are using a 75 mercy Monarch! direct swap. rear end as well minus the rear end yokes. they are different. a little cut here and there and the driveshaft will match.....the a arms and everything swap directly over
Old 09-25-2002, 01:00 AM
aka Duke of URL
Wink
[quote]Originally posted by 56don:
<strong>I put Granada brakes on a 67 Fairlane and they work great but the suspension is different on the 64 so I don't think Granada style will work.</strong><hr></blockquote>
I guess I need to clarify this...Only the spindles from the GRANAD/MONARCH are used (along with the caliper/rotor) on the big FORD. The suspension type is different but not relevant.
The spindles have to have the ball joint holes resized to accept the big FORD ball joint studs.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
