1964 Ford Fairlane 500 won't charge - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2011, 05:32 PM
I have a 1964 Ford Fairlane that was having trouble charging/maintaining a charge. I bought a brand new voltage regulator and alternator and installed them, but when a battery cable is pulled, the car won't operate. Also, the generator light stays on for no apparent reason when the car is turned off.
Any help would be appreciated, this is my dream car.
Old 08-04-2011, 05:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
you probably have a broken wire somewhere that's what i would be looking at. could possibly be the harness from the regulator back somewhere to the alternator. JMO are you sure the wires are connecting good at the regulator ?
Cole
Old 08-04-2011, 08:37 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If the generator harness (which is what your car originally had in 1964) is routed similar to my 65 Ranchero, I would be inclined to think a wiring issue in the harness.
That silly harness runs thru the radiator support and makes a few bends, then goes thru holes with no grommets.
Could be whoever installed the alternator in place of the generator, did not wire it correctly.
Old 08-04-2011, 09:28 PM
I wired it myself, it's correct.
Old 08-04-2011, 11:55 PM
dinger's Avatar
I am not sure of the Fords but when you put a new regulator on a Chev you had to cross the fields in the regulator. Maybe not for an alternator.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 08-05-2011, 04:46 AM
EOD Guy's Avatar
I'd trace every wire again...... I once had a very simular situation.... I knew the wires were right! I traced them again and what-do-ya-know I had switched the 1 and 2 wires on the alt, put them the right way and poof the, problem went away.
Old 08-05-2011, 03:15 PM
eloc431962's Avatar
Wiki Edits: 37
X2 i forgot to mention that.
Cole
1964 Impala SS - Battery Not Holding Charge 64Joker Electrical 8 07-28-2008 08:14 PM
1964 fairlane 2 door hardtop john wilson Introduce Yourself 2 08-19-2007 07:52 PM
1964 Ford Fairlane D.W.Decker Introduce Yourself 1 05-23-2006 05:28 PM
Super charge/Turbo charge Meka Engine 8 11-24-2003 06:33 PM
Turbo charge or super charge for a small block olds Andrew7dg Engine 2 11-12-2002 11:23 AM
