#1
1964 Ford Fairlane 6 cyl no spark
Have replaced coil, plug wires, dis cap, points, rotor and condenser on my 1964 fairlane and still no spark. What am i missing? Please help !
Register now (free) or login to remove ads |
#2
Got a test light or voltmeter?
Confirm that you in fact have power to the coil by grounding the test light and checking both low voltage posts on the coil, while cranking if possible. If you have no light there is no +12V getting to the coil. It should be flashing while you crank the engine if all is good when testing one side of the coil, it should be on fairly steadily on the other side of the coil. If no light or voltage disconnect the points from the scene and try again. Does your system use a ballast resistor or the 'resistive wire' that drops voltage? Both can go bad. |
#3
read this Wiki article and follw the steps and you will find the issue
Wiki Link
Artificial Intelligence is no match for Natural Stupidity Chet |
| Thread Tools | Search this Thread |
| Similar Threads for: "1964 Ford Fairlane 6 cyl no spark" | ||||
| 66 ford fairlane 500 xl, go for it? | 66-500xl | Hotrodding Basics | 34 | 12-03-2011 11:39 AM |
| 1964 Ford Fairlane 500 won't charge | house.93 | Electrical | 6 | 08-05-2011 03:15 PM |
| 1964 fairlane 2 door hardtop | john wilson | Introduce Yourself | 2 | 08-19-2007 07:52 PM |
| 1964 Ford Fairlane | D.W.Decker | Introduce Yourself | 1 | 05-23-2006 05:28 PM |
| 67 Ford Fairlane Help | 1931 steve | General Rodding Tech | 7 | 04-23-2006 01:40 PM |
