Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1964 ford station wagon
Old 11-16-2004, 01:25 PM
D351W's Avatar
D351W D351W is offline
New Member
i believe ford used the same front suspension set up from 65 to 77 or so of course back in the sixties it was drum brakes up front and in the 70's disc brakes were used,you could probably use the front suspension from a granada/monarch disc brakes,11"rotor good stopping power plus these cars are still available at the junkyards (at least in this side of the u.s) it should be a direct swap (im pretty sure you already know this...oh well)
