1964 Impala Fuse Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 08:58 PM
64Joker's Avatar
64Joker
Attached is a pic of the 64 Impala stock fuse box, the two "ignition/fused" slots are located on the upper left hand corner.
Are there no fuses associated with these slots, if not, why?
If I understand it correctly, these two slots are only "hot" in the run position (when the engine is started).
Are these two slots getting their juice directly from the battery, what's behind the configuration design?
Name:	64 Stock Fuse Box.jpg
Old 09-12-2012, 09:15 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Those two taps are fused with the Wiper and the Back-up fuses.
They are connected directly to the load side of the fuse.
However----the two slots that you have wires plugged into may not be fused.
Battery is not fused-----and pretty sure the lamps are not fused either.
If the lamp side is fused, then it is fused with the dash lamps.
I'll have to go look at a an old box later----from a 59 but not much different at all
Where oh where should my fuse box go?? steweddude Electrical 2 08-10-2010 06:59 AM
1964 Impala - Interior Heater Box Resistor 64Joker Electrical 1 02-19-2010 04:09 PM
1964 Impala - Interior Heater Box 64Joker Hotrodding Basics 1 02-12-2010 10:52 AM
Fuse box Turbo Terror Electrical 2 12-26-2004 05:58 PM
Fuse Box phil1949 Electrical 2 08-17-2003 09:33 AM
