1964 Impala "Heater Control" Unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2007, 04:15 PM
64Joker's Avatar
64Joker
Attempting to remove the interior "heater" control unit (air, def, & temp) from the lower dash, threre are 3 wire controls on the back-end of this unit that lead to the heater. I don't see any bolts/nuts/screws to remove the main unit which appears to slide onto the lower dash, anyone know how to remove the unit? Thanks in advance..
Old 01-07-2007, 05:17 PM
poncho62's Avatar
Wiki Edits: 5
The cables are probably holding it in place.........I would undo the cables at the other end...that should release the whole unit. That the way my 62 Pontiac came apart anyways.
Old 01-08-2007, 06:20 PM
64Joker's Avatar
64Joker
Task Complete
I located two brackets held by 2 bolts/nuts on the back of the heater control unit, removed the brackets and the unit slid right off, there was no need to remove the wires from the unit side. Thanks again.....
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
1964 Impala SS - Coil + wire to fusebox ? 64Joker Electrical 7 09-05-2006 03:36 PM
can't find vin# on 1964 impala fresa1214 General Rodding Tech 3 04-26-2006 02:06 AM
Engine in my 1964 Impala roll 64 Body - Exterior 4 09-21-2003 09:03 PM
Engine in my 1964 Impala roll 64 Engine 1 09-21-2003 12:37 AM
