The Resistor wire usually starts at the Bulkhead connector on the Firewall, engine compartment side.
There's also a wire that runs from the Starter up to the old Points Distributor for full 12V supply when cranking. It's not needed when using an HEI. HEI Conversions: http://rmcavoy.freeshell.org/HEI.html http://www.oldengine.org/unfaq/hei.htm |
ok so there is no resistor wire on bulkhead connector dash side just on the engine side so i dont need to remove any wires is this correct on the dash side of the bulkhead connector ?
Engine side only, should be able to trace it back to the connector from the Distributor. May find a wiring diagram, 'search engine' is the best way it'll bring up much more Info.
Most models should be about the same wire colors. 64 Nova here>> http://www.stevesnovasite.com/forums...ad.php?t=91875 |
This is for Chevelle>> http://www.chevellestuff.net/tech/hei.htm
http://www.chevellestuff.net/tech/index.htm |
yes i used the search engine but everybody states the samething used the fusebox but that is not the way i want to do it. Thats the reason i bought the HEi harness bulkhead connector i want it to look stock with out a pink wire sticking out of the fusebox so far the first method has been expline but not the other on these cars
i seen some of these links you post so if i go by what they say i dont need to do anything just put in the HEi harness bulkhead connector and iam done that dont seem right. something is missing
What does your HEI Bulkhead connector kit look like? Terminal & wire that goes into the Bulk Conn.? |
Nice Kit
Yes the Purple= S terminal & Pink= R terminal on the Starter. Look here @Post #5 >> http://67-72chevytrucks.com/vboard/s...d.php?t=312351 |
i just hook everything up and no start just a clicking sound here is a pick of the starter connection maybe i hook the wires up wrong ? i new this was not going to be a plug in play .
![]() Uploaded with ImageShack.us |
| 1964 Impala - Part Name Question | 64Joker | Hotrodding Basics | 1 | 03-21-2010 07:19 PM |
| 1964 Impala SS - Heater Blower Config Question | 64Joker | Hotrodding Basics | 6 | 12-03-2009 11:48 AM |
| 1964 Impala SS - Headliner Question | 64Joker | Interior | 8 | 07-11-2009 04:20 AM |
| 1964 Impala SS 327 | BahmerL | Engine | 9 | 04-10-2007 06:47 PM |
| resistance of plug wires? | hotroddr | Electrical | 11 | 10-09-2006 08:23 PM |
