1964 Impala Interior - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2009, 06:36 PM
64Joker's Avatar
64Joker
In preparing for my interior project, I removed two hard cardboard pieces from slots that run up/down behind the 2 doors (back side windows to floor) please see attached pic. It appears these are used for tacking interior material trim. Can someone tell me if these are sold as after market products or do interior shops just replace the originals with their stock? Thanks in advance..
Car: Impala SS
Year: 1964
Name:	64 interior.JPG
Old 07-29-2009, 05:00 AM
UngerMarkus's Avatar
Tuck´n´Roller
I recently did a ´55 Chevy headliner. I guess the same material was used for tacking the headliner to. We replaced it with stripes of plywood wich we glued on with chassis-adhesive in addition to the metal hooks.
Old 07-29-2009, 07:33 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Car: Impala SS
Year: 1964
Those are tacking strips made from fiber board and are usually 1/4 to 3/8" thick, and about 1/2" wide. In your case, they are used to staple windlace on the door openings. I used to replace them when needed with waterproof panel board strips laminated together with glue, but found that PVC foamboard strips work much better. PVC foamboard (brand names are Sintra, Komatex, and Celtec - available at most sign shops.) cuts easily with regular woodworking tools, including a table saw, and is totally waterproof. It also comes in all kinds of thicknesses, so if you don't want to laminate the strips together, you can get a piece that is the right thickness. It's also half the weight of solid PVC, and is a lot less expensive. It's available on line HERE
I'm not crazy about using plywood of any kind in a car interior. There are much better choices that are waterproof. Also, cutting plywood into strips only 1/2" wide makes it very weak.
1964 Impala SS Door Panels 64Joker Interior 4 10-13-2008 10:02 AM
1964 Impala SS Interior Roof Insulation 64Joker Interior 3 07-30-2008 10:28 AM
'58 Impala interior, what's it worth? fordSR Interior 6 02-27-2008 06:18 PM
1964 Chevy Impala flip31277 Introduce Yourself 1 06-17-2006 09:50 AM
66 Impala Mold on Interior munchhead Interior 3 03-11-2006 11:36 PM
