1964 Impala SS - Heater Repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2006, 06:58 PM
64Joker's Avatar
64Joker
I'm getting ready to repair my 40 year old heater, besides the heater core and electrical switch, what other parts should I expect to change out?
Old 11-29-2006, 07:48 PM
T-bucket23's Avatar
Wiki Edits: 26
Well that depends on what is wrong. How do you know you need a core and a switch. The two would be for unrelated problems
Old 11-29-2006, 08:19 PM
302 Z28's Avatar
While I had it apart I would also replace the blower motor.
Vince
Old 11-29-2006, 09:06 PM
64Joker's Avatar
64Joker
Reply to T-Bucket
T-Bucket "Quote" [Well that depends on what is wrong. How do you know you need a core and a switch. The two would be for unrelated problems]
It the process of replacing the interior firewall pad, I noticed the heater switch had deteriorated, literaly fell apart (appears to be original switch).
As far as the core, I was advised that it would be a good idea to replace it while I had the heater unit out.
If there are other 40 years old parts that could possibly be replaced while the heater unit is out, it would seem to be a good idea to replace them, especially if they are inexpensive parts...
Old 11-30-2006, 06:09 AM
T-bucket23's Avatar
Wiki Edits: 26
Well if you have the core out, you could just take it to a radiator shop and have them clean and presure test it. If it is good it is probably better than any replacement you will get. Everything else is pretty easy to get to like the fan and the fan resistor so they shouldnt be bad to replace if they fail later
Old 11-30-2006, 10:47 AM
Tazz
replace or repair
I would look into a replacement core. The old unit has served its purpose replace it.
Tazz
Old 11-30-2006, 06:46 PM
64Joker's Avatar
64Joker
Heater Parts Confirmation
Confirmation of Heater Parts:
Core
Heater Switch
Blower Motor
Anything other parts? What about gaskets?
Old 01-02-2010, 06:18 PM
candy63impala's Avatar
there is a outer seal that goes on the box under the hood. the inside i just used some weatherstripping,
id test the blower while i had it off,and if it works id go with it
Old 01-07-2010, 10:36 PM
Same here. Chances are a replacement is gonna be coming straight from China, and while they can turn most any product into a pile of junk that looks like it oughta work (but doesn't), they really excel at making the worst motors on the face of the earth.
Old 01-08-2010, 10:00 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
get the core tested
new hoses (rubber gets funny with age) and switch (as it's falling apart)
The motor might be serviceable- brushes and stuff. Does it spin with little resistance? If it spins with little resistance and responds well to 12v power, then I'd keep it. Put the money into a nice paint job or something.
value of 63 Impala SS hubcaps? akm Hotrodders' Lounge 10 02-04-2013 09:43 PM
68 Impala SS 327, is it a Muscle Car(tm)? 327ImpalaSS Hotrodders' Lounge 30 05-15-2008 08:25 PM
Heater core replacement/71 SS El Camino stinky jinx Engine 4 09-24-2006 07:55 AM
1964 Impala SS - Coil + wire to fusebox ? 64Joker Electrical 7 09-05-2006 03:36 PM
Can U Tell Me IF This Is A REAL IMPALA SS?? syclone477 General Rodding Tech 6 11-24-2005 04:07 AM
